Mach Discussion => Mach Screens => Topic started by: MyGarageShop on March 15, 2017, 08:49:07 PM
One day I was browsing for Mach information and I found a link (which I should have saved) that said there is a location or script or something that you can add or modify so that when your screen set loads you can script certain things...
I need to set certain OEMDRO's & OEMLED's, select a specific page etc...
All of those things I know how to do but I dont know how to automate it when the screen set loads
Can some one help? Point me in the right direction?
Thanks in advance
If you put what you want to do into a macro then that can be called at startup by adding it to the Initialization String (Config. / General Config. - Startup Modals).
