Third party software and hardware support forums. => Mach3 and G-Rex => Topic started by: Stefan2013 on August 01, 2013, 11:20:02 AM
Good morning, I have installed the software in order to control a Hummingbird M3V2 engraving machine. The instructions say that I should press the RESET button and that the exterior of the button will stay green. But in my case, this does not work. It stays in the "Emergency mode active". So what is the problem? Thanks
Stefan,
Assuming your machine has an EStop button then check that you have the right configuration for it (active hi / low, correct port and pin etc.).
If you do not have an EStop button fitted - you should really fit one but in the short term...
Choose 'Emulated' for your EStop configuration (Config / Ports & Pins / Input Signals). This should allow the on-screen RESET to be reset.
