General CNC Chat => Show"N"Tell ( Your Machines) => Topic started by: Machinehead57 on February 14, 2013, 12:25:39 AM
I have spent the past 10 months retrofitting a full sized 3HP bed mill with Gecko 320x drives and Mach3 on a HP desktop computer.
After tuning the servos and calibration of the axises I ran many jobs on it with great success. I recently built a 4th axis from a Browning
Gearbox by making a hollow bore shaft for it I could mount a chuck on and drive it with a large stepper motor. I used the stepper because I have no need for turning in the mill just spline cutting and milling parts on multiple sides with one setup. The machine runs very accurately at plenty of speed. I haven't turned the speed up to its max
as I see no reason to travel more than 120 ipm. The machine weighs about 6000 lbs and will reverse the table fast enough to shake the machine but still maintain it accuracy. It can raise the Z and lower making cuts side by side but leave no edge you can feel between the cuts. The 4th axis is sturdy enough to spline hardened axles with no vibration.
I have been a machinist for about 35 years now and the CNC machining is new to me but quite impressive in its capabilities. I do my own drawings in Autocad and use
an Autolisp routine to produse my Gcode in exactly the way I want it.
I still have plans to add a mpg to the controls and a few other accessories to make it more productive but for the time being I need to turn out paying work
to help fund this project.
If I can help anyone with my experience drop me a message and I give what I can to help.
Here is a picture of the machine modifying and intake manifold.
(http://)
Hello Machine Head
Autolisp?
I have an Acad license. If it is not your personal IP I would be very interested in trying it.
John McNamara
Hello Machine Head
Autolisp?
John McNamara
Autolisp details are here http://www.jefferypsanders.com/autolisp.html
Thanks Tweakie
Gee there are a lot of utils there I will look for the Gcode tool......Mr sanders is in OZ too.... I live in Melbourne :)
John
Nice, I want to see what the intake bolts to. Is that a Super Victor?
great to see an old bedmill get back into action, i have two denford quatro bedmills which are the same as a semco 600 and i'm running these on mach3.
Yeah its a Victor Jr going on a 500 cid Chevy with a 2000 cfm throttle body injection system a make.
The mill itself is a 1989 which isn't old for a machine tool but the computers have came along way since.
It had the Delta 10 controller on it originally.
Nice, remind me later of a great story concerning a 69 Camaro with a 416 small block. I guarantee you a good laugh. It's pretty lengthy and I type to slow so I will have to do it later.
OK it keeps saying I have replied but its not showing up. This is the lisp routine I use. It came from Lindsey Engraving and is free to use modify and share.
Check it out.
Steve
Hi Machine head
Thank you very much....
John McNamara
That's interesting... I have the exact same machine that I plan on retrofitting hopefully soon. It is one solid machine. I sent you PM.
accuartisans, where are you and when would be a good time to call?
Steve
I am in North Georgia, today I have a granddaughter's birthday this morning to go to, but anytime this late afternoon or tomorrow. Whatever works better for you.
When I saw your picture I was shocked! I had to go out to the garage and take a double look at my machine. The only difference I could see is that my spindle head is slightly different.
Sent from my GS III using Tapatalk 2
