G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: michel-cnc on November 12, 2011, 06:54:17 AM
Hello !
I have tried Eagle & pcb-gcode following example at
http://www.instructables.com/id/Turn-your-EAGLE-schematic-into-a-PCB/
I have generated the G-code and have a look to the result given by pcb-gcode and i can see problems with the toolpath generation:
there are some shortcuts !!
You can have a look to the joined files: i put a screen copy of the settings in pcg-gcode (it runs under eagle) and the result.
If somebody have some hints, they are welcomed !
Looks like you have lots of errors on that PCB.
Mach cannot help resolve those issues, the GCode needs to be right before Mach becomes involved.
The only thing I can suggest is that you practice using Eagle and PCB-GCode a bit more or perhaps ask some questions at the Eagle forum http://www.cadsoftusa.com/forums/guidelines/?language=en
Not much help really, sorry.
Its also quite possible that the gap is too small for the cutter that you specified. ie, the gaps 1mm and the cutter is 1.5mm.
