Tangent Corner => Tangent Corner => Topic started by: Overloaded on February 10, 2011, 12:15:14 PM
Hi All,
I gutted a piece of equipment from a financial institution and pulled this PS.
I've never seen one quite like this one.
110VAC in, says 28V out of the blue cap. (40,000uF, 40 VDC, Max surge - 50 VDC)
The gray cap says 3uF 660v. What is its purpose ?
How can I determine the MAX wattage of this unit ?
You will need to know the current it can deliver.
You cannot calculate the wattage only knowing the output voltage.
There's an AC capacitor and a DC capacitor for filtering DC output currant.
The output currant is more stable with the output capacitor, will prevent small ripples of voltage.
Jeff
Hi Jeff,
Thanks for the info.
No way ? I was hoping there was a way to determine the current available.
The voltage is probably too low for any practical CNC app anyway, I suppose.
To the dump !
Thanks again,
Russ
