Mach Discussion => Video P*r*o*b*i*n*g => Topic started by: Tristar500 on November 30, 2009, 05:04:52 PM
It was suggested that I pose this question here on the video probing forum even though I'm using a touch probe..
Thanks!
I'm looking for a way to edit the code generated by the digitizing wizard (not plug-in) to a more usable format. The file Mach generates is missing the x, y and z characters and simply separates the coordinates with a comma.
I could generate a point cloud in my cad program if the code was simply edited to include the X, Y and Z letters in each line..
Here's an example
Here's what I have to start with from Mach
-6.032136,1.419120,0.835333
-5.907102,1.419120,0.822000
-5.782069,1.419120,0.803333
-5.657035,1.419120,0.776000
This is what it needs to end up as so my cad/cam can read it.
X-6.032136,Y1.419120,Z0.835333
etc..
Any suggestions?
You could use a word processor.
Replace all the "-" with "X-"
Replace all the ",1" with "Y1"
Replace all the ",0" with "Z0"
Of course this only works if the first number for Y is different than the first for Z.
Ron
if you're any good with Excell you could write a macro to do this automatically... splitting it up after every comma...
Al Lenz has written a brilliant little VB program to do just this. It is called XYZ Converter.exe and can be downloaded from this page.
http://www.machsupport.com/forum/index.php/topic,13301.msg87229.html#msg87229
I can write a simple C program do do that, but how do you get if from a triplet to a usable mesh?
Update: I have written a Windows CPP app for this. Now what?
Update: nevermind, found MachCloud
I am not in front of my machine right now, but I think in one of the preferences or settings you can turn on/off having the coordinate letter or not.
Rick
Rick is right......if this is what you need.
Ports and Pins / Mill Options
