Mach Discussion => General Mach Discussion => Topic started by: imajeenyus on October 19, 2007, 03:39:49 PM
Hi.
I have the demo of Mach3, however I don't see the jogging control panel (continuous/increment, step size, jog speed etc) like in Mach2. Do these appear in the release version or are they hidden away somewhere in the program?
Lindsay
press the tab key and you will get a pop out for these controls.
I am accustomed to TurboCnc and new to Mach3. In a few hours I had very little difficulty applying most of my TurboCnc configuration info to Mach3.
I only use incremental jogging.
I see that Alt-J is used to change the jog increment to the next smaller size. What key is used to change the jog increment to the next larger size?
Accidentally changing from the smallest to the largest jog increment can be disastrous. How can I disable jog increment table wraparound?
Tom Hubin
thubin@earthlink.net
Alt J will toggle through the range, you keep pressing it and it will go from biggest to smallest then start over again .
I am having problems with jog. I am new to pc based cnc so please have patience. I had Mach3 working with jog working in both continuous and incramental using both mouse and keyboard to actuate them. For some reason (probably me doing something wrong) now the keyboard doesn't control jog and I am unable to get the incramental functions to light up or work. Any clue how to fix this. I tried to reinstall Mach3 but the problem persists. I would like to reset the system if that is possible. ANY assistance appreciated.
Jack Mc Kie
Is the jog enable on? From the program run screen, lower center.
Brett,
Thanks! Your assistance very much appreciated! Now all I have to do is learn how to use Mach3.
Kindest Regards,
Jack Mc Kie
I personally do not like the "Cycle" increments, it can be dangerous.
What I have is a DRO that I can enter the value I want, I also have my most common amounts that I use on 4 buttons, that way I known when I it the "0.001" button that it will always be set to that.
If you open up your screen in "Screen 4" or use a Flash screen I would recommend adding 4 buttons. You could use Mach codes as well:
Select Step value 1 Button 265 (1.000)
Select Step value 2 Button 266 (0.100)
Select Step value 3 Button 267 (0.010)
Select Step value 4 Button 268 (0.0010)
Select Step value 5 Button 269
Select Step value 6 Button 270
Select Step value 7 Button 271
Select Step value 8 Button 272
Select Step value 9 Button 273
Select Step value 10 Button 274
Set Jog mode STEP (same as button 205) 275
Set Jog mode CONT (same as button 204) 276
Alternatively, you can send the value and turn on Incremental mode using Flash script or VB script...if you need help with the script let use know.
If for that day you have a comman distance your traveling you could have a DRO that you enter the value to store the value and on a button send it.
No problem Jack, that one has bitten me before too. LOL
Good idea Jason, I think I will use that when building my MPG pendant.
Great. I have done enough C programming for DOS and Windows in the past that I can probably handle the programming itself. Where I need help right now is finding out how to copy, rename, and modify an existing screen. Is the script editor part of the Mach3 download? I have downloaded other stuff like the SDK but have not installed anything but Mach3 itself.
My main interest in Mach3 is for laser triangulation. I have some professional experience in laser triangulation hardware and software design. Right now I am concentrating on hardware but may want to fool around with the software later. I presume that this involves more than just scripts. Probably writing and linking to c or VB subroutines. Can you point me toward reading for the process of grabbing a single USB Webcam frame?
Tom Hubin
Hi, Tom
Look hear Screen4 bottom of page, http://www.machsupport.com/artsoft/downloads/downloads.htm
Make a copy of your C:\Mach3\Mach3Mill.xml and give it a try.
Hope this Helps, Chip
To modify a screen you can use Screen4.exe, you will find it in the Mach3 folder on your HDD.
You can get the VB Editor if you go to the Operator menu in MACH 3.
Edit
see Chip beat me to it by an hour LOL, I need sleep :)
Hood, It doesn't happen to often, Chip
LOL
