Hello
Guest
it is
June 10, 2026, 05:13:24 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
SmoothStepper USB
(Moderator:
Warp9TD
Some information about port 2
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Some information about port 2 (Read 12605 times)
pedro
5
on:
December 28, 2008, 10:18:44 AM »
hello, as I wish to use some rotary encoders for MPGs, those:
http://it.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=263-2889&x=15&y=10
and I want use port 2 pins 2-9 that are described on manual as CMOS thresholds inputs, I wish to know if it mean have 1 level to 12 volts or 5? If I will use the CD4504 TTL to Mos translator can I assume it will do the work?
Thanks in advance
Last Edit: December 28, 2008, 10:20:46 AM by pedro
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Some information about port 2
Reply #1 on:
December 28, 2008, 01:53:00 PM »
you should be able to connect this with a 5 volt supply and connect it straight to the breakout board.
Or have a look at these, these work even better
http://homanndesigns.com/store/index.php?main_page=product_info&cPath=15&products_id=30
Graham
pedro
5
Reply #2 on:
December 28, 2008, 04:54:26 PM »
thank you very much for the help and prompt answer. I realy already have some of the encoders I posted, I will try with them
Print
Pages:
1
Go Up
« previous
next »
