May 28, 2012, 02:39:31 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Silly but handy button scripts. Help Calc Wiki
Pages: 1   Go Down
Print
Author Topic: Silly but handy button scripts. Help Calc Wiki  (Read 1191 times)
lhaddix
Active Member
Offline Offline
View Profile
« on: December 21, 2008, 09:09:33 PM »
Get tired of leaving Masch to fire up the winfows calc?
Place this under a button.
Shell(calc.exe)
I also wanted a button to open the PDF, without having to know the path to Acrobat. So I did this:
Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA"(ByVal hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String,ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
ExecuteLink("Mach3Mill_1.84.pdf")
Public Sub ExecuteLink(Link As String)
   On Error Resume Next
   Dim lRet As Long
   If Link <> "" Then
       lRet = ShellExecute(0, "open", Link, "", CurDir())
       If lRet >= 0 And lRet <= 32 Then
           MsgBox "Error jumping to:" & Link, 48, "Warning"
       End If
   End If
End Sub
I also wanted to be able to bring up the Wiki. Use the previous scipt but replace the
line ExecuteLink("Mach3Mill_1.84.pdf")
with  ExecuteLink("http://www.machsupport.com/MachCustomizeWiki/index.php?title=Main_Page")
I take no responsibility for how stable this is because I not used it much so far, but it seems fine.
Landrum
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #1 on: December 21, 2008, 10:18:53 PM »
Thanks for shareing Landrum.  Smiley
Time savers are great.
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
Pages: 1   Go Up
Print
Jump to:
