Hello
Guest
it is
June 09, 2026, 09:38:09 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Newfangled Solutions Mach3 Wizards
(Moderator:
Ron Ginger
V2.81
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: V2.81 (Read 56695 times)
TDAY
165
Re: V2.81
Reply #10 on:
December 08, 2008, 09:53:41 AM »
Found out why CW and CCW is backwards
I was reading description beside the CW & CCW,that is what is backwards, but when selectting CW or CCW and not going by description,program is right.
Sorry for not paying attention.
Troy
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
Sage
370
Re: V2.81
Reply #11 on:
December 08, 2008, 06:39:07 PM »
Yes. I pointed that out as well.
And I'll repeat it here because your description is still confusing (to me)
On the pocket data entry screen CW is listed as "climb milling". It is actually conventional milling.
(If you pick clockwise it does generate a clockwise movement - it didn't use to that's waht was fixed in 2.81)
Sage
Last Edit: December 08, 2008, 06:42:43 PM by Sage
Sage
370
Re: V2.81
Reply #12 on:
December 27, 2010, 04:24:04 PM »
Hi Ron:
Seems this has gone un-corrected.
In the interest of making everything correct could you change the descriptions of CCW and CW in the circular pocket wizard. A CCW path is climb milling and CW is conventional milling while inside a pocket.
The code does go CW when you select it. It's just the descriptions that need to be corrected.
(or maybe I got confused)
Sage
Print
Pages:
1
2
Go Up
« previous
next »
