May 28, 2012, 02:35:28 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Mach3 ShutDown
Pages: « 1 2   Go Down
Print
Author Topic: Mach3 ShutDown  (Read 3623 times)
giannis121
Active Member
Offline Offline
View Profile
« Reply #10 on: August 24, 2009, 07:57:53 AM »
Cooooool
robinho.sl
Active Member
Offline Offline
View Profile
« Reply #11 on: August 24, 2009, 07:33:37 PM »
if you want, you can put more one line to performa a shutdown without confirmation:
SendKeys "%+{F4}"
SendKeys "ENTER"
The "ENTER" will confirm the exit without a user's confirmation. (I always hated the close confirmation)
Using the config of windows its possible remove the title bar and close buttons, using only our close button. Also is possible run on fullscreen hidding all windows plataform. If is interesting for you, i can upload the ConfigFiles and help to do this...
Róbson Machado Rosa
Brazil
giannis121
Active Member
Offline Offline
View Profile
« Reply #12 on: August 25, 2009, 12:27:06 AM »
Personaly, i am interested.
Thanks!
robinho.sl
Active Member
Offline Offline
View Profile
« Reply #13 on: September 24, 2009, 01:44:57 AM »
wow!! i'm so sorry...
i did this request a long time ago.. but i forgot to publish.
I dont have the files now, but tomorrow i will post the files. I make a tutorial too. ^^
i see that you are on line now... xD
its good
jorber
Active Member
Offline Offline
View Profile
« Reply #14 on: October 01, 2010, 02:06:47 PM »
its good
please publish the tutorial to do that, thanks
dizzyy
Holding
Offline Offline
View Profile
« Reply #15 on: June 05, 2011, 04:30:48 PM »
good day
Help with this idea
need to add the button and led
and at the end of the program comes across Mohmand M999, and the script checks razhatie button, and depending on the state gives the go-ahead to turn off or not
Help, I'm in the scripts complete zero
zafarsalam
Active Member
Offline Offline
View Profile
« Reply #16 on: July 01, 2011, 06:02:48 AM »
its good
I use this Autohotkey script to hide the title bar in Mach. You'll have to install Autohotkey from www.autohotkey.com first.
Run, c:\mach3\mach3.exe /p mach3mill , c:\mach3
Loop
   sleep, 20
   Until winexist("Mach3 CNC")
WinActivate
WinSet, Style, -0x800000
WinMove, , , -4, -4, 1034, 771
Pages: « 1 2   Go Up
Print
Jump to:
