Hello Guest it is June 09, 2026, 03:19:31 AM
Author Topic: Well i finally uploaded my 6 axis screen, was 5 axis.......  (Read 226126 times)
Offline Tarak
  •  229 229
As you'll see I got lazy and didn't finish it all, most of it is done though, I'd like to make sure most of it works before I change some of the other pages around.
Let me know your thoughts or ideas and maybe I can implement them.
Im sure you are all aware to copy the folder into Mach3\Bitmaps and the 6 axis screen into \Mach3.
I made it 6 axis, because it's easier to remove a couple of axis than it is to add them.
« Last Edit: July 10, 2006, 07:06:07 AM by Darc »
ynneb
Re: Well i finally uploaded my 6 axis screen, was 5 axis.......
« Reply #1 on: July 10, 2006, 06:22:45 AM »
I have just tried to install it but cant work out what to do with the second zip file. where does it all go?
Could you also please post a screen capture into this thread. :)
Offline Tarak
  •  229 229
« Reply #2 on: July 10, 2006, 07:03:04 AM »
Sorry, the UT Buttons-JPG folder goes into the MillBitmaps folder, and the 6Axis screenset goes in Mach 3 base directory.
I just modified the zip file to make it easier.
ynneb
« Reply #3 on: July 10, 2006, 07:17:19 AM »
Yes that worked ok.
NICE Work !!!
Thats a great contribution.
I will add this to the new downloads page ( Soon to come)
Thanks for sharing.
« Reply #4 on: January 20, 2007, 04:33:14 AM »
Is this screen for 6 axis free?
If not, how much?
Michael
Offline Bloy
  •  158 158
« Reply #5 on: January 20, 2007, 06:30:32 AM »
 I like this!
I'm sorry, ....a little bit slow here...
Could you explain how to install files in their correct places to get this to work?
I have the folder "UT buttons-JPG"  in the Mach3 "bitmaps",
                        The "6Axis.set" file in the Mach3 directory in C:
I still am at a loss to get this to work.
Help!
never mind... just need glasses
« Last Edit: January 20, 2007, 06:38:59 AM by Bloy »
« Reply #6 on: January 21, 2007, 12:41:57 PM »
Hey Darc,
    I have some new pages, to the original 5 axis control of mine that you Snazed-up, would you mind "Snazing up", some extra pages like a few different types of  ATC set up/control page's?
Also, I have just finished a 4 Axis Foam cutting Screen, and a 4 axis Wire EDM screen, any chance you would be interested in "Snazing" those up as well?
Scott
Offline Tarak
  •  229 229
« Reply #7 on: January 21, 2007, 02:04:16 PM »
Hi Michael Haber, the 6 axis screen is free, it's still a bit buggy though, I will upload a slightly better one shortly.
poppabear, I can update a screenset for you if you like. Either upload it to hear or PM me.
« Reply #8 on: January 22, 2007, 01:20:14 PM »
Thanks Darc, I have downloaded your 6 axis screen, it looks fine.
But at present I have problems with PCI - printer ports,
so I can run again my 5 axis router I am developing.
Tried Kouwell PCI I/O cards, two off them, non work.
Art is suggesting to use LAVA product, but they have no agent in Australia.
Any other products you can, or anyone else suggest?
Michael Haber
« Reply #9 on: January 23, 2007, 08:38:10 AM »
Check out Rogers Site, he sells PCI cards, that put out 5v.
forgot his website, but he has a link here somewhere, Brian for sure knows it since he was helping him with his following error feedback stuff.
Scott
