Hello
Guest
it is
June 09, 2026, 04:33:28 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
PoKeys
(Moderator:
NeoTO
Pot to stop axis
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Pot to stop axis (Read 37482 times)
Carnoustie, Scotland
Pot to stop axis
on:
November 23, 2008, 05:56:03 PM »
For anyone interested I have made up a Brain so that if I turn my FRO pot to minimum it will feedhold then when I turn up again it will start the code running again. Seems to work fine here but as usual test with caution and at your own risk
Re: Pot to stop axis
Reply #1 on:
November 24, 2008, 03:35:37 PM »
Heres another Brain that might be of use, it sets the FRO to 100% if the FRO is between 98 and 102%, stops the FRO LED constantly flashing and makes it easy to set pot to 100%.
Chaoticone
5,624
Precision Chaos
Reply #2 on:
November 24, 2008, 04:09:48 PM »
Those are great Hood. Just proof your not just another pretty face.
If you could see the things I have in my head, you would be laughing too.
Reply #3 on:
November 24, 2008, 04:14:18 PM »
Last Edit: November 24, 2008, 04:33:03 PM by Hood
budman68
2,352
Reply #4 on:
November 24, 2008, 04:35:40 PM »
Just wanted to chime in here and say that even though I'm not utilizing these functions now, I do appreciate the info being here when I may need it.
Thanks so much, Hood-
Dave->
Reply #5 on:
November 24, 2008, 04:40:52 PM »
no problems Dave, just want this for the lathe as it will be perfect for testing out new code especially now you can lock the rapids and FRO. Means you can slow right down or even stop as the tool is aproaching the stock.
Reply #6 on:
November 30, 2008, 07:53:30 PM »
Have updated the Brain to do the same for the Spindle override as it does for the FRO.
Print
Pages:
1
Go Up
« previous
next »
