Hello Guest it is June 09, 2026, 04:36:18 PM
Author Topic: Rectangle wizard not putting out feed speeds. 2.79 bug?  (Read 34619 times)
« on: November 22, 2008, 06:51:02 PM »
I am trying to cut 2 simple rectangles using a 1/8" tailn bit for some molex plugs.
I have gotten the coordinates right, but the plunge feed and the feed rate is the same. I have entered 10% of max for plunge, and 100% for feed (10 IPM) is what I want, but in the rectangle wizard, it isn't putting out a feed rate, just a plunge feed of 1. Am I missing something?
Also, is there a prefered screen size for newfangled, there are a few wizards that have boxes covered by buttons and the 2.79 label is inside a title bar once a wizard is selected.
Here is the code:
(Code by Newfangled Wizard, 11/22/2008)
(Program Posted for Aluminum )
G0 G49 G40.1 G17
G80 G50 G90 G98
G20 (Inch)
(***** Cut Rectangle *****)
M6 T3
M03 S3500
M9
G00 G43 H3 Z0.2
(Inner rectangle)
(conventional mill)
G00 X-0.1875 Y-1.4188 F10
G41 P0.0625
G01 X-0.0938 Y-1.4188
G03 X0 Y-1.325 R0.09375
G01 Z-0.01 F1                              <<<<<<<<<<<<<<< Plunge Feed>>>>>>>>>>
G01 X0 Y-1.325           <<<<<<<<<<<<< Feed rate missing >>>>>>>>>>>>
G01 X0 Y-0.95
G01 X-0.7 Y-0.95
G01 X-0.7 Y-1.7
G01 X0 Y-1.7
G01 X0 Y-1.7
G01 X0 Y-1.325
G01 Z0.2                              <<<<<<<<<<<<<<  Retract speed option would be nice too >>>>>>>>>>>>>>
G03 X-0.0937 Y-1.2313 R0.09375
G40
G01 X-0.1875 Y-1.2313
(Inner rectangle)
(conventional mill)
G41 P0.0625
G01 Z-0.02 F1                        <<<<<<<< Plunge Feed >>>>>>>>>>>
G01 X0 Y-1.325                            <<<<<<<<<<<<<< Again, Missing Feed Rate >>>>>>>>>>>>>>>>>.
G01 X0 Y-0.95
G01 X-0.7 Y-0.95
G01 X-0.7 Y-1.7
G01 X0 Y-1.7
G01 X0 Y-1.7
G01 X0 Y-1.325
G01 Z0.2
G40
(Inner rectangle)
(conventional mill)
G41 P0.0625
G01 Z-0.03 F1
G01 X0 Y-1.325
G01 X0 Y-0.95
G01 X-0.7 Y-0.95
G01 X-0.7 Y-1.7
G01 X0 Y-1.7
G01 X0 Y-1.7
G01 X0 Y-1.325
G01 Z0.2
G40
(Inner rectangle)
(conventional mill)
G41 P0.0625
G01 Z-0.04 F1
G01 X0 Y-1.325
G01 X0 Y-0.95
G01 X-0.7 Y-0.95
G01 X-0.7 Y-1.7
G01 X0 Y-1.7
G01 X0 Y-1.7
G01 X0 Y-1.325
G01 Z0.2
G40
(Inner rectangle)
(conventional mill)
G41 P0.0625
G01 Z-0.05 F1
G01 X0 Y-1.325
G01 X0 Y-0.95
G01 X-0.7 Y-0.95
G01 X-0.7 Y-1.7
G01 X0 Y-1.7
G01 X0 Y-1.7
G01 X0 Y-1.325
G01 Z0.2
G40
G00 G43 H3 Z0.2
(Inner rectangle)
(conventional mill)
G00 X1.0125 Y-1.4188 F10
G41 P0.0625
G01 X1.1063 Y-1.4188
G03 X1.2 Y-1.325 R0.09375
G01 Z-0.01 F1
G01 X1.2 Y-1.325
G01 X1.2 Y-0.95
G01 X0.5 Y-0.95
G01 X0.5 Y-1.7
G01 X1.2 Y-1.7
G01 X1.2 Y-1.7
G01 X1.2 Y-1.325
G01 Z0.2
G03 X1.1063 Y-1.2313 R0.09375
G40
G01 X1.0125 Y-1.2313
(Inner rectangle)
(conventional mill)
G41 P0.0625
G01 Z-0.02 F1
G01 X1.2 Y-1.325
G01 X1.2 Y-0.95
G01 X0.5 Y-0.95
G01 X0.5 Y-1.7
G01 X1.2 Y-1.7
G01 X1.2 Y-1.7
G01 X1.2 Y-1.325
G01 Z0.2
G40
(Inner rectangle)
(conventional mill)
G41 P0.0625
G01 Z-0.03 F1
G01 X1.2 Y-1.325
G01 X1.2 Y-0.95
G01 X0.5 Y-0.95
G01 X0.5 Y-1.7
G01 X1.2 Y-1.7
G01 X1.2 Y-1.7
G01 X1.2 Y-1.325
G01 Z0.2
G40
(Inner rectangle)
(conventional mill)
G41 P0.0625
G01 Z-0.04 F1
G01 X1.2 Y-1.325
G01 X1.2 Y-0.95
G01 X0.5 Y-0.95
G01 X0.5 Y-1.7
G01 X1.2 Y-1.7
G01 X1.2 Y-1.7
G01 X1.2 Y-1.325
G01 Z0.2
G40
(Inner rectangle)
(conventional mill)
G41 P0.0625
G01 Z-0.05 F1
G01 X1.2 Y-1.325
G01 X1.2 Y-0.95
G01 X0.5 Y-0.95
G01 X0.5 Y-1.7
G01 X1.2 Y-1.7
G01 X1.2 Y-1.7
G01 X1.2 Y-1.325
G01 Z0.2
G40
M5 M9
M30
Re: Rectangle wizard not putting out feed speeds. 2.79 bug?
« Reply #1 on: November 23, 2008, 09:53:44 AM »
Looks like a real bug. I see it also outputs an F word on a G00 line, which is wrong.
I have another report of a problem with the cut rectangle not getting depth right, so Im going to work on both problems.
Mach assume all screens are 1024x768 including the wizards. It is supposed to scale the screens if oyuuse a different screen size, but In not sure it always works. What screen resolution do you use?
« Reply #2 on: November 23, 2008, 09:11:56 PM »
1280x1024.
Thanks for checking this out.
« Reply #3 on: November 24, 2008, 06:09:24 PM »
Did you have trouble with the Inner option actually cutting OUTSIDE the line?
I have fixed the code to add F words, and I have fixed it to really do inner and outer, climb and conventional correctly-at least I think they are correct, Ive tried each option.
Attached is a zip file with these fixes. Ill leave it here a while as a test, then Ill make it the release version if there ar eno problems.
Just unzip the file in the Addons folder. You might leave it as Newfangled280, that way it wont overwrite your current version. Just be sure when you select it form the list you select the right one.
I deleted V2.80 and posted 2.81 to a new topic.
« Last Edit: December 04, 2008, 09:33:51 AM by Ron Ginger »
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #4 on: November 26, 2008, 08:07:59 AM »
Inner Climb Cut rectangle does not preview while in wizard.But does in Mach3.Before first run of program there is a very wacky comp move,but when i stop then reset program and regen toolpath the comp then works fine.
HTH
Troy
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
« Reply #5 on: November 26, 2008, 09:18:08 AM »
You are right, I forgot to fix the preview code. One of the problems with the way VB works in Mach is that you cant share code, so the preview button is exactly the same code, without the spindle controls.
Ill fix that later today.
I dont understand the wacky comp move, maybe some mode you have set before it runs? Ill see if I can find anything, Im going to run a complete set of test cases later today.
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #6 on: November 26, 2008, 09:30:55 AM »
Version 2.79 comps just fine,and plunge feedrate and cut feedrate are both there.But the Preview is wrong,as u stated u need to fix.
HTH
Troy
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #7 on: November 26, 2008, 12:40:01 PM »
Soory made a typo :( Should have been 2.78 not 2.79. But feedrate problem is in 2.78 also.
sorry again,
Troy
« Last Edit: November 26, 2008, 12:47:52 PM by TDAY »
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #8 on: November 26, 2008, 01:01:04 PM »
Also noticed in 2.80. When doing an outside Rectangle that tool comes out of part turns off comp then back on and then tool goes back down to do next pass depth.
Troy
