Hello Guest it is June 11, 2026, 12:11:36 PM
Author Topic: Mach XML Reader  (Read 681425 times)
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Mach XML Reader
« on: November 17, 2008, 09:16:51 AM »
Mach XML Decrypter/Organizer
(Programmed in C++ and Action Script)
-Nothing to install
Translates your Mach XML into a format that is easy to find what you’re looking for and organizes it.
-Unzip “Mach_XML_Reader.zip”
-Double click the “Mach_XML_Reader.exe”
-Drag and drop a XML file in to the window
 Easily load and view your XML settings:
1.   Data grid layout to Easley find and understand setting.
2.   Organize the XML by: Settings, Parameter or values.
3.   Edit, Save and Back up your XML.
4.   Search Parameter by names.
5.   NO need to close the window just keep dragging and dropping XML’s
Enhancments needed to be made:
1.             Search feature you have to type the word identical to the parameter
2.             Save changes before going to the next "Settings". Example if you make changes under "Preferences", you will need to hit the save button before going to "Control" or your changes are lost.
If there are enough people using this and report back of features they would like to see added, then I will finish up the “Search word” feature.
Currently to find what you want with the search feature you have to type the word identical to the parameter, I can code it as you type it will organize the data (like Google does now), but this will take more time and if people don’t use it there is no reason for me to add it.
Please always backup your XML :)
« Last Edit: November 18, 2008, 05:29:56 AM by zealous »
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Mach XML Reader
« Reply #1 on: November 17, 2008, 09:18:35 AM »
Here is the download:
I will modify this topic with the newest version and a list of updates if people like it  ;)
Re: Mach XML Reader
« Reply #2 on: November 17, 2008, 09:43:10 AM »
Jason,
    Nice work!  I like it!
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: Mach XML Reader
« Reply #3 on: November 17, 2008, 10:42:39 AM »
Wow.. Very nice editor. Definitley going into amy Favorite utilities folder.
 Excellent programming Jason..
Art
Re: Mach XML Reader
« Reply #4 on: November 17, 2008, 10:47:00 AM »
Yeap! What he said!!
Scott
Re: Mach XML Reader
« Reply #5 on: November 17, 2008, 12:20:18 PM »
Thats the dogs dangly bits
Re: Mach XML Reader
« Reply #6 on: November 17, 2008, 06:27:26 PM »
SUUUUPER  COOL   ;)
Ed
Ed VanEss
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Mach XML Reader
« Reply #7 on: November 18, 2008, 05:32:01 AM »
Hope it helps and thanks for the feedback  ;D
Re: Mach XML Reader
« Reply #8 on: November 18, 2008, 08:05:50 PM »
Jayson,
Nothing gives the tool guy a greater joy than a tool that just does something well.
Looks like you gave a new qualiity screw driver or wrench for the box!
Re: Mach XML Reader
« Reply #9 on: November 20, 2008, 01:34:51 PM »
Zealous,
When I click Mach_XML_Reader.exe, inside the zip file or after extraction I get the Alpha Graphic Designs AGD logo and an Application error with intruction at 0x746ad2f3 uses memory address 0x00000c58 . The memory cannot be read.
Or, if I keep trying I get the error Access violation at address 00140199. Write of address 00000310
Or Exception EAccessViolation in module ntdll.dll at 00011760.
I'm using XP.
Anything I can do?
Gaston
