May 28, 2012, 02:25:34 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  PoKeys (Moderator: NeoTO)
| | |-+  New firmware issue-
Pages: « 1 2   Go Down
Print
Author Topic: New firmware issue-  (Read 2458 times)
Active Member
Online Online
Carnoustie, Scotland
View Profile
« Reply #10 on: November 09, 2008, 11:09:02 AM »
Switching axis is done in Mach, on my screen I have buttons on the front page. I  also have real buttons on my panel to do it. You can however just press the Tab key and on the flyout you can change between axis.
 I have 100 pulses per rev and they work very well but if you are planning to use for actual machining rather than just positioning as I do then you probably want 500 or more.
Pages: « 1 2   Go Up
Print
Jump to:
