December 02, 2008, 06:52:12 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Promote and discuss your product .
| | |-+  Multifunction CNC Board
Pages: 1   Go Down
Print
Author Topic: Multifunction CNC Board  (Read 2241 times)
arturod
Active Member
Offline Offline
View Profile WWW
« on: July 05, 2006, 06:53:19 PM »
This new board comes with many of the features of the other boards that I have been offering.  I believe users will find they will save time and reduced wiring as it already comes with many built in features.  It is also great for use in systems that are already in place since it comes with a DB25 connector for output.
Check out the board at:
http://www.cnc4pc.com/Multifunction_CNC_Board.htm
The features of this board are:
• Fully optoisolated
• Built-in Safety Charge Pump.
• Built-in Variable Speed Control.
•Built-in 10 amp AC Solid State Relay.
• Built-in 8 amp Solid State Relay with NO and NC positions.
• All pins can be used in a concurrent manner.
• Buffered outputs.
• Status LEDs on all inputs and output connections.
• Has an extra DB25 female connection for output.
• Output pins 1, 2, 3, 4, 5, 6, 7, 8, 9, 14, 16, 17.
• Input pins 10, 11, 12, 13, 15.
• Input and output pins with close by ground connections.
• Easy installation of an On/Off switch. You can control the card externally.
• All TTL 5VDC signals.
• Works directly with popular CNC hardware and software.
• Screw-On connections for all terminals.
Arturo Duncan
http://cnc4pc.com
« Last Edit: July 05, 2006, 10:33:26 PM by ynneb » Logged
kemo181
Holding
Offline Offline
View Profile
« Reply #1 on: March 14, 2007, 04:19:01 PM »
Hi arturod
Is the Board Fully assembled and should I have seperate Stepper drivers for the board and finaly is it a 6axis controler amd witch motors can it control
Regards Kemo181
arturod
Active Member
Offline Offline
View Profile WWW
« Reply #2 on: March 14, 2007, 04:34:22 PM »
Yes,
The board is fully assembled. It is for 4 axis only.  Yes, you will attach the steppers to this board.  If you need 6 axis, take a look at this board http://www.cnc4pc.com/Store/osc/product_info.php?cPath=33&products_id=45. The picture is from the first version of this board.  We are currently shipping revision 3 of this board.  Take a look at the new picture.
Arturo Duncan
KRAM242
Active Member
Offline Offline
CanNotCompute-CNC
View Profile
« Reply #3 on: June 15, 2007, 08:05:12 AM »
Is this board for unipolar or Bipolar  steppers?
Mark
DennisCNC
Active Member
Online Online
View Profile
« Reply #4 on: July 25, 2007, 08:28:34 AM »
^^ This is a break out board not a stepper driver board.
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
