Hello Guest it is June 09, 2026, 08:45:33 AM
Author Topic: Gecko G320 wiring question  (Read 10466 times)
« on: October 24, 2008, 11:40:18 AM »
Hi all,
I am in the process of wiring a new controller for my mill using Gecko G320 servo controllers.  A question I have is wiring the "Optional External Fault LED Circuit" from page 5 of the Gecko G320 Installation Notes (dated April 3, 2008).  This circuit allows you to reset the servo controller externally, plus it gives you an LED indication whenever there is a fault.  What has me confused is the way to wire it.  There is a arrow pointing "To Computer", but I do not know how I will wire that to my BOB (CNC4PC C11G) since it is only one wire (I am used to two wires to create a circuit).  Has anyone wired this circuit, and if so, can you give me some pointers?
Thank you and God Bless,
Steve
Re: Gecko G320 wiring question
« Reply #1 on: October 24, 2008, 02:00:10 PM »
Hi, you can connect the wire "to computer" to your one of your bob inputs. the wires that say 5v to your bob +5v power supply and 0v ground wires (the up-side down triangle with striped bars) to the bobs supply 0v.
John
« Reply #2 on: October 24, 2008, 02:10:06 PM »
John,
Thank you so much.  I have been scratching my head about this connection.  Much appreciated.
God Bless,
Steve
