Hello Guest it is June 11, 2026, 09:15:16 PM
Author Topic: Need Help with Pokey & Mach  (Read 119205 times)
« on: October 21, 2008, 05:22:46 PM »
I need help setting up a button input in mach3. I want to set up an external reset button with Pokeys. I have the updated plugin for mach and I have the current version updated in the pokeys board.  I have enabled pin 13 on the pokeys board as an input. In mach I have set up port 10 input 13 in the ports and pins setup, in the mach hotkeys setup I have set trigger 13 to oem code 1021. Please tell me if I have done something wrong. Nothing happens when I press the button. I bring up the pokey diag menu in mach and it does not show anything happening when I press the button. If someone could please help me with this one input setup the rest will be easy.
Tom
Offline borisz
  •  220 220
    • www.poscope.com
Re: Need Help with Pokey & Mach
« Reply #1 on: October 21, 2008, 05:31:34 PM »
Hi!
Are you using 1.9 version of PoKeys software and latest Mach plugin? They are both on www.poscope.com
Did you saved configuration to PoKeys device?
regards
Boris
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
« Reply #2 on: October 21, 2008, 05:34:32 PM »
You need to set the OEM Trigger in ports and Pins to Port 10 Pin 13, as you seem to like the number 13 ;) it is the Oem Trig 13 you need to set to that port and pin number. If that is what you have done then it should work fine presuming you have the switch wired properly (Pin 13 on pokeys, through switch to ground pin)
« Reply #3 on: October 21, 2008, 05:58:50 PM »
Thanks for the reply Hood.  I have the current versions installed, the switch is wired correctly I know because before I hooked it up to mach I was able to use it to launch a program when I was playing with it when I 1st got it.  Do you know if in the plugin control menu, pokeys dialog, when I press the button hooked up to the input should it show in the window that is is active?
Tom
« Reply #4 on: October 21, 2008, 06:00:18 PM »
It should show the state of it and the state should change when you press it.
« Reply #5 on: October 21, 2008, 06:01:56 PM »
I forgot to mention that I am also using the smooth stepper. One other question, Do I need to somehow enable port 10 in Mch somehow?
Tom
« Reply #6 on: October 21, 2008, 06:03:12 PM »
Hood, Nothing happens when I press the button on the diag Menu.
Tom
« Reply #7 on: October 21, 2008, 06:03:45 PM »
Try to switch to another USB port.
« Reply #8 on: October 21, 2008, 06:03:59 PM »
SS shouldnt be a problem, and no you dont have to enable port 10.
If you want attach your xml and I will check you have the pins set correctly, if you do then it at least eliminates that.
« Reply #9 on: October 21, 2008, 06:18:34 PM »
try run mach3 when pokeys setup program still runs in background.
Josep
