Hello
Guest
it is
June 11, 2026, 12:40:00 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
AH-HA into Mach 3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: AH-HA into Mach 3 (Read 10912 times)
bfairey
40
AH-HA into Mach 3
on:
October 07, 2008, 12:16:58 AM »
I am on the verge of firing up a MACH3 into a AH-HA box via a SmoothStepper.
The main problem is making the cable from the SS 20p connector to the AH-HA
DB36 pin connector.
Will keep you informed.
Brian.
bowber
216
Kirkby Stephen,Cumbria, UK
Re: AH-HA into Mach 3
Reply #1 on:
October 07, 2008, 04:16:33 AM »
Hi
I just removed all the AH-HA stuff and used a newer computer with Mach 3.
Are you reusing the AH-HA interface card?
Steve
bfairey
40
Reply #2 on:
October 07, 2008, 07:15:56 AM »
No I dont think the interface card will work with MACH3
I also brought a new(er) computer so decided to use the USB port
thats why I am using the SmootheStepper board as it will take the USB
connection.
Brian.
Print
Pages:
1
Go Up
« previous
next »
