Hello
Guest
it is
June 12, 2026, 03:54:25 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach3 under Vista
Vista
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Vista (Read 21306 times)
antony_vm
9
Vista
on:
September 30, 2008, 06:11:09 AM »
Hi All,
Have been using a plasma for sometime.
Really impressed to see what mach can do with XP.
Now that MS decided to discontinue XP, will Mach be able to deliver its punch in Vista.
Any problems if I change to vista?
Last Edit: September 30, 2008, 08:16:01 PM by antony_vm
Jeff_Birt
1,107
Re: Vista
Reply #1 on:
October 03, 2008, 10:54:10 PM »
You would probably be advised if you read through all the posts in this section...It will go a long way towards answering your question.
Then you'll be prepared to ask more pointed questions and receive meaningful answers...
Happy machining , Jeff Birt
Check out
www.soigeneris.com
Print
Pages:
1
Go Up
« previous
next »
