May 28, 2012, 02:13:29 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Newfangled Solutions Wizards (Moderator: Ron Ginger)
| | |-+  Getting wizard to append to existing code
Pages: 1   Go Down
Print
Author Topic: Getting wizard to append to existing code  (Read 1219 times)
Sage
Active Member
Offline Offline
View Profile
« on: September 27, 2008, 02:14:47 PM »
It was my understanding that when running the NFS wizards several times it was supposed to add the new code to the end of existing code in MACH. Each time I run a wizard it wipes out the previous code already in MACH. What am I doing wrong?
Sage
Ron Ginger
Active Member
Offline Offline
View Profile WWW
« Reply #1 on: September 28, 2008, 12:28:35 PM »
The wizard builds one big program per session. Each run is a new session and starts with a blank file. Every operation you do adds to that file, which is loaded into Mach when you end the wizard run.
But it does not save code from one run to the next. It does however remember the settings you used the last time it ran so when you open each operation the values shown are the ones from the last time you ran that operation.
Sage
Active Member
Offline Offline
View Profile
« Reply #2 on: September 28, 2008, 01:31:31 PM »
 Ok. I see how it works now. I guess it makes more sense now that (with the new 2.79 version) you can see the G-code in the Wizard preview window. I was exiting back to Mach to see if the code made sense to what I was asking for. In fact I open a separate notepad file, do an "edit code" in Mach and cut and paste each individual code segment into my new file - editing the new bits, the comments and the inbetween stuff along the way. I may continue doing it that anyway as I thnk I end up with a cleaner final result quicker.
Sage
Pages: 1   Go Up
Print
Jump to:
