Hello Guest it is June 12, 2026, 02:45:52 PM
Author Topic: Ref. All Home - Limit tripped Will not ref.  (Read 13391 times)
« on: June 13, 2006, 07:25:39 PM »
Hey Guys and Gals!
I'm almost there with the lathemaster milling machine conversion, but I need help again.  When I tell my milling machine to reference home all, my z axis rides to the top of the tower, trips the switch and reverses as it is suppose to.  Before the home command satisfies itself and proceeds to the next axis, I get a limit switch active for the z and the program disarms the system.  I have the soft limits set at 0 and -7 for now and have the soft limits button not active.  I've set the home/limit ref value to .1 and -.1 but nothing works.  It seems to work sometimes and not on most others.  I hope I have described this so someone can understand and help!  Wonderful site for us beginners.
billyjack
 ;D
Re: Ref. All Home - Limit tripped Will not ref.
« Reply #1 on: June 14, 2006, 09:47:35 PM »
Try setting the debounce to about 1500 under the Logic settings :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: June 15, 2006, 05:20:22 AM »
Thanks Brian;
I did that very thing yesterday and cleared up my problem.  Guess I should have read more before I posted.
Thanks again!!!
billyjack
