November 20, 2008, 06:01:28 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  dspMC/IP motion controller (Moderator: vitalsystem)
| | |-+  Mazak Retrofit
Pages: 1   Go Down
Print
Author Topic: Mazak Retrofit  (Read 265 times)
maquiza
Active Member
Offline Offline
View Profile
« on: September 18, 2008, 02:07:47 PM »
To Rufi,
Hello, I am planning a Mazak retrofit, but I am stock in one issue, I need a 6V/1000 rpm signal from the servo motor to the servo drive (a tachometer dc signal), Can dspMC/IP send that signal to the servo drive, using the encoder input, and send also the command signal of +-10V at the same time? This is a 4 axis machine, and I need this in all axis.
Thank You,
Jorge
vitalsystem
Active Member
Offline Offline
View Profile
« Reply #1 on: September 18, 2008, 06:11:01 PM »
hello Jorge,
this feature as you know is normally done in the hardware by tachomemeter.  sorry the DSPMC software is not designed to convert encoder counts to analog signal.  you can easily do that in hardware.
regards,
Rufi
« Last Edit: October 18, 2008, 11:59:34 PM by vitalsystem » Logged
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
