Hello Guest it is June 11, 2026, 06:06:38 PM
Author Topic: 1/12 SCALE MILLING MACHINE PARTS  (Read 42308 times)
Re: 1/12 SCALE MILLING MACHINE PARTS
« Reply #10 on: September 02, 2008, 08:33:46 PM »
Jeff
Didn't you ever hear of Leprechaun's?  ;) I get the small ones at 4 for a $ at the local flea market. Trouble is they keep disappearing when it's time to do work. Will never get the mill done!  ;)
« Reply #11 on: September 03, 2008, 11:29:43 AM »
The more I look at these the more I love them. Fantastic work and as my wife would say, "how friggin cute are those!?!?"
  •  9,356 9,356
« Reply #12 on: September 04, 2008, 03:19:16 AM »
Was that the machines she was talking about Dave ?
« Reply #13 on: September 04, 2008, 03:53:53 AM »
funny guy!  :D
« Reply #14 on: September 17, 2008, 12:16:52 AM »
Rich,
  Freakin Fantastic. You gonna set them all up on a line shaft?
Only 1 motor needed. I remember them days.
Ed
Ed VanEss
« Reply #15 on: September 17, 2008, 02:46:15 PM »
Ed,
No line shaft, although they do work. I just have themĀ in small display cases.
Currently sitting on top of the sterio speakers in the family room. They look so much nicer than the
ugly vases from my mother in-law.
 ;D  RICH
« Reply #16 on: September 17, 2008, 03:50:40 PM »
Rich.
   LOL, Yes, motherinlaws tend to do that. Give you all the ugly crap.   ;D
Look what I got.
You can't find any 1/12 scale cnc stuff either ?   :D
Good job.
Ed
Ed VanEss
« Reply #17 on: May 04, 2009, 07:10:14 PM »
Hi All,
Time to start making some more parts for the model again. The pictures show one of the universal joints completed for the model. I could of just softened a bearing and drilled two holes thru it, but,  instead I decided to CNC turn the ball.
Attached is the gcode for machining the ball and a picture of the pointed tool used. The code does a complete finishing pass after the roughs. You need a tool which will not gouge the ball as it goes around it. You don't need to change tools when done this way and and the part has a nice finish.
« Reply #18 on: May 04, 2009, 07:33:11 PM »
NEATO MAN !
Nice work RICH..THANKS for the update.
RC
« Reply #19 on: May 04, 2009, 07:45:24 PM »
Nice job Rich,
But , I want to see it cnc ed.  :D
For outside radiuis , I usually use a outsie radius mill cutter clamped in the tool post . gives you an accurate radi without having to grind a tool bit.
But if you don't have , then you sharpen a tool bit.
Thanks for the update.
Ed
Ed VanEss
