May 28, 2012, 02:05:54 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Two state button
Pages: 1   Go Down
Print
Author Topic: Two state button  (Read 1301 times)
zealous
Active Member
Offline Offline
View Profile WWW
« on: June 08, 2006, 04:48:49 AM »
Try to figure out how to call on two states of a button to call on two diffrent wave files.
I got creative and used some of the Display button code, it works but also effects the state of the display screen.
Was wondering how a programer would do this Huh Tried a few diffrent ways to go about it, but I'm still learning coding.
I tried changing "Boundry" but the code skips over and only plays one of the sound waves for each button state.
Here is the code if you have any idea.
value = GetParam("Boundry")
Public Declare Function sndPlaySound Lib "winmm.dll" Alias "sndPlaySoundA" _
    (ByVal lpszSoundName As String, ByVal uFlags As Long) As Long
 If value= 1 Then
 SetParam "Boundry" , 0
 DoOEMButton(103)
 sndPlaySound "C:\WINDOWS\MEDIA\ding.wav", &H1
 Else
 SetParam "Boundry" , 1
 DoOEMButton(103)
 sndPlaySound "C:\WINDOWS\MEDIA\tada.wav", &H1
 End If
Regards, Jason Blake
www.Fusioncnc.com
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #1 on: June 08, 2006, 05:37:25 AM »
Try this Smiley
value = GetVar(1)
If value= 1 Then
Call SetVar(1, 0)
DoOEMButton(103)
Else
Call SetVar(1, 1)
DoOEMButton(103)
End If
Fixing problems one post at a time Wink
www.newfangledsolutions.com
www.machsupport.com
zealous
Active Member
Offline Offline
View Profile WWW
« Reply #2 on: June 08, 2006, 10:13:10 PM »
Thank you Mr.Baker that works great Grin
While reading the PDF I had come across "GetVar" .
I thought I might be able to  declare a value and give it an on/off statement.
Your codes sweet!!! and a little sexy Cheesy
I'm putting together some pretty cool sound sets for Mach. I'll post them when there ready.
www.Fusioncnc.com
Pages: 1   Go Up
Print
Jump to:
