May 28, 2012, 02:05:38 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Newfangled Solutions Wizards (Moderator: Ron Ginger)
| | |-+  V2.79
Pages: « 1 2   Go Down
Print
Author Topic: V2.79  (Read 3185 times)
TDAY
Active Member
Offline Offline
View Profile
« Reply #10 on: November 18, 2008, 12:09:07 PM »
In the Cut Rectangle there looks like there is a DRO under the depth DRO.
Also the preview does not show the correct amount of passes.But it does show the correct amount of passes in the Mach3 display.
And when doing an inside cut, the selection of a Climb or Conventional cut is backwards.
Do i have a setting wrong?
Troy
« Last Edit: November 18, 2008, 12:53:51 PM by TDAY » Logged
"I try to put forth the effort,before asking a dum question"
Ron Ginger
Active Member
Offline Offline
View Profile WWW
« Reply #11 on: November 18, 2008, 05:26:41 PM »
Sorry, I dont know what you mean by "there looks like there is a DRO under the depth DRO."
I will check the other issues, There have been other cases where the preview codes did not exactly match the post code. Ill see what I can find.
TDAY
Active Member
Offline Offline
View Profile
« Reply #12 on: November 19, 2008, 07:02:34 AM »
The 2 depth DROs must have been a glitch in screens,because it has went away.
Troy
Pages: « 1 2   Go Up
Print
Jump to:
