Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 02:04:40 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
FAQs
Setup Problems
Pages:
1
Go Down
« previous
next »
Author
Topic: Setup Problems (Read 2248 times)
skratch_73
Holding
Offline
Setup Problems
on:
August 23, 2008, 01:06:41 AM »
I have went through everything in the setup videos and for mach3 and read on the forums, tried many motor tuning as suggested in the forums and I am still having a problem. The issue is that after setup, when I enter in shuttle mode to go .100 that's fine in +/- of 0.000. but any thing past that, It starts adding .002 to .004 for every .100!? my .001 inch moves are only about .0001 and anything over .100 well Who Knows(one of those Mind Of It's Own things). I have the nema34 steppers 425, xylotex board. Everything I run in mach3 without the steppers on does just fine . good example, I bored a hole a depth of 1.23, Nope it thought 1.85 is where it wanted to go and Did. Any help on this issue would of great thanks.
Thanks Sam
Overloaded
Global Moderator
Offline
Re: Setup Problems
Reply #1 on:
August 23, 2008, 01:13:32 AM »
Double check your "Steps Per" setting in the motor tuning window.
Maybe run the auto utility on the settings page. I think that's where it is. Dont have Mach right now, on antique laptop.
RC
"I haven't failed. I've just found 10,000 ways that won't work." Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
Cincinnati
Active Member
Offline
Re: Setup Problems
Reply #2 on:
September 17, 2008, 05:27:46 PM »
Sounds like your "Steps per inch" needs further adjustment.
I went to 1" increments to set motor tuning. This made it easy to set steps per inch.
My baseline was 20,000 steps per inch. Dividing by 1000 mils/inch translates to 20 steps per mil.
You state you are getting 1.020 when you command a move of 1.000. Look at your "Steps Per" setting. Divide by 1000 to give your steps per mil.
Place carriage with the carriage in the middle of travel range. Remove backlash. enter G0 X1. Record how far it actually moved. Enter X1 again and Record actual distance moved. Repeat this a total of 5 times. Average the actual distances.
Multiply the average actual distance greater than 1.000 by your steps per mil and subtract it from the "steps per" in the motor tuning window. Run the test again with the new steps per, and repeat adjusting until you get an acceptable number.
Repeat for each axis.
Last Edit: September 17, 2008, 05:30:13 PM by Cincinnati
Barneydog
Active Member
Offline
Re: Setup Problems
Reply #3 on:
December 12, 2008, 03:39:47 AM »
I set mine up near enough then used the auto calibration on the diagnostics page. I clamped a digital caliper onto the axis i was testing. Once the auto had got as close as it could and was alternating each side of the movement I went back to manual setting in the motor tuning section and made very small changes until on the auto test run I was getting the correct movement. To avoid any automatic update just leave the units moved result box at zero.Now on a move of 25mm I get 24.99 to 25.01 which is probably near enough.
Regards
Julian.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
