December 02, 2008, 06:11:13 AM
Search:     Advanced search
+  Machsupport Forum
|-+  G-Code, CAD, and CAM
| |-+  Lazy Cam (Beta)
| | |-+  autocad vs. lazycam
Pages: 1   Go Down
Print
Author Topic: autocad vs. lazycam  (Read 258 times)
uuccimi
Active Member
Offline Offline
View Profile
« on: August 20, 2008, 09:23:38 AM »
How can open a DXF file onto LazyCam after was made out in Autocad
I did click OpenDXF in LazyCam but No Entities Found...
uuccimi - novice
BobsShop
Active Member
Offline Offline
View Profile
« Reply #1 on: August 20, 2008, 09:57:05 AM »
Did you close your dxf file that AutoCad created?  If the file is still open, it won't load into LC.
Bob@BobsShop - Been there done that.
uuccimi
Active Member
Offline Offline
View Profile
« Reply #2 on: August 20, 2008, 10:34:43 AM »
Ok, I did close autocad, try to open with Lcam, but won't load any thing and see 2749.87 scale number in the blue screen
uuccimi - novice
ger21
Global Moderator
Online Online
View Profile
« Reply #3 on: August 20, 2008, 10:50:58 AM »
Save as V12 .dxf from AutoCAD and try that.
uuccimi
Active Member
Offline Offline
View Profile
« Reply #4 on: August 20, 2008, 11:46:43 AM »
Thanks ger21
V12.dxf  works!!!
uuccimi - novice
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
