Hello Guest it is June 11, 2026, 02:40:39 AM
Author Topic: Brain Timing and "Latches"  (Read 12641 times)
« on: August 18, 2008, 10:32:06 PM »
I'm assuming brains are run periodically, like every pass through the main loop of Mach3?  I've become quite expert at writing brains that end up in endless loops, madly toggling things, or, in too many cases, hanging Mach completely, so I have to re-boot the machine.  Are brains evaluted/executed at a fixed time interval?  Is this why the "Timer" lobes are provided, to prevent race conditions?  If so, what is an appropriate delay to prevent races?
Also, what does the "Latch" lobe function do?  I've found no explanation anywhere.
One last question - Are functions limited to arithmetic expressions, or can we use logical expressions as well?  For example, if I want to have a lobe output one of two numeric values, based on the value of a boolean input, how would I do that?
Re: Brain Timing and "Latches"
« Reply #1 on: August 30, 2008, 04:20:58 PM »
Brains runs with machs update loop.
you can do values, via formulas feed by booleen results into the formula.
scott
« Reply #2 on: March 01, 2009, 11:00:07 PM »
I too also have the same question about what the latch function does....  Anyone?
« Reply #3 on: March 03, 2009, 07:38:05 AM »
If memory serves......
the "Lathed" function is so that when your conditions are met from 2 or more inputs, that once they become True, then the box will "Latch" itself into an ON state even when the Inputs become false, per run of Mach.
If is for if you have a certain pattern of inputs/conditions that when they occur (even Once), that the result will Stay on.....
scott
Offline CJEls
  •  69 69
« Reply #4 on: March 17, 2009, 03:13:24 AM »
Hallo Scott
Do you have a example of a latching circuit.  How do you reset the latch.
Thank you
CJ
« Last Edit: March 17, 2009, 03:27:38 AM by CJEls »
