Home
Downloads
Mach and LazyCam
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
German Forum
Italian Forum
Portugese Forum
Resources
Links
User Reviews
User Videos
Contact Us
CNCZone
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
December 02, 2008, 07:58:52 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
Brains Development
Low Spindle Speed limit
Pages:
1
Go Down
« previous
next »
Author
Topic: Low Spindle Speed limit (Read 281 times)
ggagnon
Active Member
Online
on:
August 18, 2008, 12:50:52 PM »
New to brains.
I would like to prevent (or stop in an orderly manner) execution whenever the spindle rpm is lower that the a certain % of set speed.
The objective is to prevent scrapping a job if the spindle slows down abnormally after many hours of work.
How would you do this with a brains?
Gaston Gagnon
HimyKabibble
Active Member
Online
Re: Low Spindle Speed limit
Reply #1 on:
August 19, 2008, 09:21:35 AM »
Gaston,
I"m hardly an expert, having created my first brain yesterday, but I would expect you'd want a brain that monitored the spindle RPM DRO, and whether the spindle is running. Test the spindle RPM, and, if too low, force the program to stop, by sending either a Program Stop or E-Stop button press. I wouild think you could use the "Spindle is Running LED" to know that the spindle is on. You'll also want a delay on the Spindle is Running LED input, to prevent the brain from executing before the spindle has come up to speed.
poppabear
S S SYSTEMS, LLC
Global Moderator
Online
Briceville, TN, USA
Reply #2 on:
August 30, 2008, 05:22:42 PM »
set up a brian that has a User DRO to set you Low limit speed, and use an LED to enable the brain to function once you up to intial speed, then have it Pause when Speed to low.
Brain is attached below.
In Screen Designer 3 or 4 open your screen and put the below into it.
You will need to drop a "UserDRO 2000" onto your screen somewhere so you can set the "Too slow" RPM limit. (you can change this limit by changing the value
in the DRO (remember to tick off "Persistant DROs" under General config if you want it to retain from BOOT up to Boot up.
You will need to drop a "User LED 2000" somewhere with a VB button that will allow you to toggle its state from on to off, and back
this LED is what will control if the above brain will be activly watching your spindle or not. (so you can turn it on and off at will).
NOTE!!!!!!!: It uses "TRUE Spindle RPM" Dro to base its compares off of, so you WILL have to have Tack Feed back so Mach can know
what your actual Spindle speed is in the real world.
The VB code needed in that button is:
If GetUserLED(2000) Then
SetUserLED(2000, 0)
Else
SetUserLED(2000,1)
End If
scott
SpindleRPMwatch.brn
(3.25 KB - downloaded 14 times.)
All things Mach3, Screens, Wizards, Plugins, Brians, complete control solutions for complex machines, Macros, ATC's, any kind of CNC machine build, retrofit or repair.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*e*i*n*g
=> Mach Screens
=> Feature Requests
=> Non English Forums
=> FAQs
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> Lazy Cam (Beta)
=> LazyTurn
=> dspMC/IP motion controller
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Promote and discuss your product .
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
=> One on one phone support.
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
Loading...
