December 02, 2008, 08:05:00 AM
Search:     Advanced search
+  Machsupport Forum
|-+  G-Code, CAD, and CAM
| |-+  G-Code, CAD, and CAM discussions
| | |-+  Defining two objects as one
Pages: 1   Go Down
Print
Author Topic: Defining two objects as one  (Read 167 times)
wlarry
Active Member
Offline Offline
View Profile
« on: August 17, 2008, 05:56:12 PM »
Hopefully somebody can help me out.  I am trying to create a sign (plasma cut) of a horse, with text.  In corel X4, I can create the text sitting on a line and "weld" them together.  Sheetcam will recognize the text and line.  When I try to add the other object, sheetcam doesn't see it.  Does anybody have a step by step "idiots guide" to creating simple signs with pics and text ?
Graham Waterworth
Administrator
Online Online
West Yorkshire, England
View Profile WWW
« Reply #1 on: August 18, 2008, 09:18:09 AM »
Make sure you are NOT outputting the line data as a spline from Corel X4
You need to save the lines as line segments.
Graham.
G-Code is on the cutting edge
Autovalues Engineering, CNC machining specialists, Bradford, England
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
