Hello Guest it is June 09, 2026, 12:22:43 PM
Author Topic: dual x axis direct drive jumpy  (Read 40900 times)
Re: dual x axis direct drive jumpy
« Reply #10 on: August 17, 2008, 05:21:21 PM »
parallel
« Reply #11 on: August 17, 2008, 05:24:33 PM »
Sorry, I mean a link to the website of the makers. I have done a google and cant find any info on it.
it's easy-cnc
« Reply #12 on: August 17, 2008, 05:25:26 PM »
Reduction gearing or a microstepping driver.
RC
it's microstepping driver
« Reply #13 on: August 17, 2008, 05:26:17 PM »
Hi, I think I have the same board, is they're pot on the board with test pins, you have to adjust each to about 5 volts(2 times the current of 2.5 amp) for the current and about 2.5 volts for the others.
http://cgi.ebay.com/4-AXIS-CNC-ROUTER-OR-MILL-STEPPER-MOTOR-DRIVER-BOARD_W0QQitemZ330262172457QQihZ014QQcategoryZ78197QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Is it this board?. yes this is it
http://www.easy-cnc.com/web/download/Manual4Axis(NEW).pdf
« Reply #14 on: August 17, 2008, 05:31:58 PM »
Have you adjusted the pot as oastie said?
Do your axis move the correct distance when you MDI a move?
« Reply #15 on: August 19, 2008, 01:26:45 PM »
sep volts and amps are good, measurments are repetable to .oo1 over ten or more repetions
« Reply #16 on: August 19, 2008, 02:52:09 PM »
Looks like gearing maybe the only way then, what are your steps per unit set at and is this imperial or metric you are using?
« Reply #17 on: August 19, 2008, 04:17:14 PM »
units a imperial, steps per is a ripping 802.8114176 vel is 5 accel is 5 the driver is set to 1/8. Your conclusion is same as mine, if I make a 4:1 transmission it'l be very close to the acme im using on the y axis. Plus I can use the machine to make most of the parts now. Beats drilling sawing and lots of file work. Wow I just noticed your a Scott, wow isn't the internet a neat thing?
Oh, and thanks for all the ideas and thoughts
« Reply #18 on: August 19, 2008, 04:35:09 PM »
Your motor will do 1 turn for every 1600 pulses so the carriage moves almost 2 inch for each rev of the motor? Can you get a smaller wheel on the motor?
Well almost, I am a Scot ;)
No probs, like to help when I can :)
« Reply #19 on: August 20, 2008, 01:18:50 AM »
 ;D picturing Mario headbanging with a kilt on.
