December 02, 2008, 07:19:40 AM
Search:     Advanced search
+  Machsupport Forum
|-+  G-Code, CAD, and CAM
| |-+  G-Code, CAD, and CAM discussions
| | |-+  Need tip on cutting path line by using Knife??
Pages: 1   Go Down
Print
Author Topic: Need tip on cutting path line by using Knife??  (Read 159 times)
amas leong
Holding
Offline Offline
View Profile
« on: August 11, 2008, 11:57:16 AM »
Hi Guy, Need Tip, is anyone know, how it work.?
I  build a CnC Machine which need to Cut soft Paper form Broad about 5mm Thick. & is using Cutter Blade. which need to following
the Path-Line, which mean the Blade will Rotate by control the step motor.- following the Path line?
or Cutting 90 or 45 degree, the Blade will rotate to 90 or 45 degree & step down to do the cutting. is Mach3 can do it?
Just like .....Zund Packing Cutting Machine.
Any Tip & Advice?
Amas
ger21
Global Moderator
Online Online
View Profile
« Reply #1 on: August 11, 2008, 12:36:29 PM »
I don't know how to set it up, but yes, mach can do that using it's tangential function to keep the knife aligned with the cutting path.
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
