December 02, 2008, 05:38:03 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| | |-+  Mach causing Galil to shut off motors
Pages: 1   Go Down
Print
Author Topic: Mach causing Galil to shut off motors  (Read 205 times)
AMorris
Active Member
Offline Offline
View Profile
« on: August 11, 2008, 11:35:11 AM »
New problem that just started this weekend. I have a Galil 1842 and Mach, was working fine but now when I try to jog x or y on the main page, or try to run a program, I get the message "begin not valid with motor off" or something close. I go to MDI page and I can move the x and y. I can also move them fine in Smart Terminal. When this happend on the main page, the X DRO shows about 1/2 an inch of movement, but the motor instantly shuts off and there is no motor movement at all. This just started all of a sudden and I am sure I have not changed any settings. I verify that the motors are shut off in Smart Terminal, I have to do an SH to get them back on. It doesnt seem to affect the Z axis. I can still jog it from the main page. Somehow, Mach is giving Galil the MO command on x and y as soon as I try to jog or run a program.
AMorris
Active Member
Offline Offline
View Profile
« Reply #1 on: August 15, 2008, 01:48:43 PM »
Still having the same problem. Last night, when I forst started Mach, I could jog X and Y and Z just fine. As soon as I tried to run a program, X DRO said it moved .53" and immediately shut the x motor off without it moving at all. It also diables my X drive, but no others. Then after doing a couple of resets, nothing would work when running a program. I could not even jog the Y axis, but I could jog Z. Meanwhile, I can go into smart terminal and run any motor I like just like nothing is wrong.
I doubt anyone else has seen this. I am tempted to format the hard drive and start all over.
AMorris
Active Member
Offline Offline
View Profile
« Reply #2 on: August 18, 2008, 11:05:35 AM »
For anyone who might benefit.
I found I had an encoder on my X axis acting up. Mach tried to accelerate that axis and the Galil shut the motor off because of too large an encoder error. I played with the motor in Smart Terminal and discovered this to be the case. At low speeds and accels, it worked fine, but as the accel increased, I would lose encoder pulses. I have US Digital encoders, and i re-adjusted the positioning of the disk and the problem went away.
One more thing I have discovered, I cant use GalilTools with Mach. GalilTools requires a different driver and Mach would not recognize the card. I rolled back to the Smart terminal driver and Mach sees the Galil fine.
Hope this info helps someone else.
Chaoticone
South Carolina, US
Administrator
Online Online
Precision Chaos
View Profile WWW
« Reply #3 on: August 18, 2008, 11:59:32 AM »
Thanks for those tips. Another useful user posting useful information.  Smiley
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
