Hello Guest it is June 13, 2026, 02:52:16 AM
Author Topic: conect switches to lpt port  (Read 9464 times)
« on: August 07, 2008, 04:50:58 AM »
I want to connect some switches to my second parallel port can i switch from ground to pin or is it important to use 5V extern for that?
can I connect them directly or should i use 5k resistor??
greets from sunny Austria
Re: conect switches to lpt port
« Reply #1 on: August 07, 2008, 05:20:16 AM »
If you are connecting direct to the PP then a normally open momentary  switch to ground is all thats needed.
« Last Edit: August 07, 2008, 05:22:37 AM by Hood »
