Hello Guest it is June 09, 2026, 04:37:37 AM
Author Topic: Using Arrays  (Read 49948 times)
Using Arrays
« on: June 02, 2006, 09:05:10 AM »
Hello
Has anyone got any experience of using arrays ?
I want to create a 2 dimensional array that stores desired spindle speed against actual speed as entered by the user.
The values are taken fom two dro's - spindle speed and a user one.
Anybody done soemthing like this before?
Also will the array be available globally so I can use other buttons in a wizard to edit the array?
Re: Using Arrays
« Reply #1 on: June 02, 2006, 09:43:47 AM »
You can't have a global Array :( But you can use the 1999 Vars in Mach3 ;) To write to a var Call SetVar(100,1.234) this will set Var 100 to 1.234 and to get the Test = GetVar(100)  will set Test to what is in Var100
That is how I do global stuff in Mach3
www.newfangledsolutions.com
www.machsupport.com
