December 02, 2008, 06:22:11 AM
Search:     Advanced search
+  Machsupport Forum
|-+  G-Code, CAD, and CAM
| |-+  Lazy Cam (Beta)
| | |-+  Cut Order
Pages: 1   Go Down
Print
Author Topic: Cut Order  (Read 203 times)
TrainHound
Active Member
Offline Offline
View Profile
« on: August 03, 2008, 10:18:53 AM »
Is there a way I can change the cut order in lazy cam pro?
budman68
Master of the Custodial Arts better known as:
Global Moderator
Online Online
View Profile
« Reply #1 on: August 03, 2008, 11:17:29 AM »
Absolutely, you should watch the videos here:
http://www.machsupport.com/videos/
While it might not look exactly the same version as yours (because LCam is has been upgraded since then), the theory is the same. The one you'll want to watch is Introduction to LazyCam and the time he starts talking about the order of cuts is around 6:41
Hope that helps-  Smiley
Dave->
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
