May 28, 2012, 01:49:52 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach SDK plugin questions and answers.
| | |-+  Finished Plugins for Download
| | | |-+  6 Axis Independant JogSpeed control for PP Plugin
Pages: 1   Go Down
Print
Author Topic: 6 Axis Independant JogSpeed control for PP Plugin  (Read 2599 times)
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« on: August 02, 2008, 12:49:04 PM »
Greetings,
   This plug in is a Smaller cousin to the Modbus one, It will allow Independant Jog speeds of up to all 6 axis, but you can use it on the Parrallel Ports!!!
You can use it for Independant Axis Jogspeed scaling from Emulated Keys, or real External Inputs through the PP.
It includes Example:
1).  MachScreen: "1024IndependantJogPP.set"
2).  XML: "IndependantJogPP"
3). Flash Help File that has a Walk through tutorial on setup and use, with pics.
Just down load the installer, and install.
The Installer called: "IndependantJogPP_vs_1.1.zip" is attached to this post.
NOTE:  Fixed the installer, in where you can download and install it to any Directory that you have mach3 installed in, the Plugin Help files will now connect to that different location.
Scott
* IndependantJogPP_vs_1.1.zip (2133.56 KB - downloaded 487 times.)
« Last Edit: August 07, 2008, 05:22:04 PM by poppabear » Logged
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
Active Member
Online Online
Carnoustie, Scotland
View Profile
« Reply #1 on: August 04, 2008, 03:45:56 PM »
Scott
 did some testing eventually Roll Eyes
 I was using the PoKeys to put physical button as  jog keys in on Port10 and it worked exactly as it should Smiley
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« Reply #2 on: August 04, 2008, 07:38:37 PM »
SWEET!!!!
I was wondering about if it would work with Po-Keys......  I didnt know if the port 10 stuff would throw stuff off.......
Scott
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #3 on: March 10, 2011, 08:42:29 PM »
BRAVO Scott ... bravo !
Very handy piece of work you have done here.
I'm missing the bitmaps from the RUN screen and the "extra" screen.
The Flash help stuff is excellent !
Russ
"I haven't failed. I've just found 10,000 ways that won't work."         Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
Pages: 1   Go Up
Print
Jump to:
