Hello Guest it is June 09, 2026, 11:49:31 AM
Author Topic: [MACH3 with G100] ecode=777, ecode=790, ecode=813  (Read 41261 times)
« on: July 29, 2008, 02:19:28 PM »
 Dear all G100 user!
 Hi! I'm Kris.
 I'm using MACH3 with G100. And I have some problem.
 First I can launch firmware load when Grex shows me red light.
 And I can ping Grex always. 0% loss. So I'm sure I have static IP adress.
 But after motor tuning in Mach3, I always see error message as attached file.
 I did searched all topic about "ecode=777", "ecode=790" and "ecode=813".
 And I tried all firmware and plugin I can get. (But I'm not sure I have right...)
 Does anybody know about this problem?
 Please help me~~~  ;)
Re: [MACH3 with G100] ecode=777, ecode=790, ecode=813
« Reply #1 on: July 29, 2008, 02:29:42 PM »
Kris, how is your G100 connected to the network? Is it through your PC on a second network connection with the first network connection being your internet connection? If so, are you using a crossover cable to connect the G100 to its network connection? What is the IP address of both network connections?
Have you looked at the manual? It may help. Here is a link.  http://www.machsupport.com/docs/G100_Set_Up_Guide_Rev.1_9-19-07.pdf
« Last Edit: July 29, 2008, 02:33:23 PM by Chaoticone »
« Reply #2 on: July 29, 2008, 03:31:05 PM »
Hi Brett!
Oh! you checked my topic so fast! Thanks!!
I reply your question as following.
Please let me know what I have to do.
1. My computer is not connected Internet.
2. GREX directly connected PC with crossover cable.
3. Computer's IP adress is 192.168.1.100. And Gres's IP adress is 192.168.1.10.
4. I have read the manual so many time...T.T And I did as the manual so many time...T.T
Please help~~~!!
Please~~~~~
Best regard. ^^
« Last Edit: July 29, 2008, 03:35:45 PM by yngsfan »
« Reply #3 on: July 29, 2008, 05:57:45 PM »
Think you will have to be able to get the Grex to the net to be able to upload the firmware.
« Reply #4 on: July 29, 2008, 10:45:38 PM »
Thanks Brett!!
But...
Even Grex isn't connected to the net, but I can download the firmware and upload it, isn't it?
Please let me know which plugin and firmware is right one.
Best regard.
« Reply #5 on: July 29, 2008, 10:52:33 PM »
The links in the set up guide should point you to the latest plug-in and firm ware. Will confirm net acces to upload firm ware but pretty sure you'll have to have an internet connection to do it. Been a long time since I did that.  :P
« Reply #6 on: July 29, 2008, 11:28:17 PM »
Thanks brett!!
Then I got right firmware and plugin as the manual. the screen shot was matched with the manual.
And....You mean I have to connect Grex through router?
-Kris-
« Reply #7 on: July 30, 2008, 12:18:08 AM »
I don't think you will have to have an internet connection to update the firmware but you will have to have the communication with the PC haveing mach and the plug-in installed in place.
« Reply #8 on: July 30, 2008, 08:59:30 PM »
Then I have to buy a router... Ahhhh...
OK... I'll try...Thanks very much! ^^
« Reply #9 on: July 31, 2008, 05:59:56 AM »
No, I don't think so. You can connect the G-100 direct to PC with a crossover cable.
