Hello Guest it is June 10, 2026, 09:29:44 PM
Author Topic: Threading wizard  (Read 19046 times)
Vmax
Threading wizard
« on: December 10, 2005, 02:44:05 PM »
Brian did you have time to work on the threading wizard? Can I download the lastest NFW without downloading the latest version of Mach3? I like to wait before upgrading Mach versions. Terry Parker
Re: Threading wizard
« Reply #1 on: December 10, 2005, 02:57:20 PM »
Sorry, what threading wizard are you talking about?? the one in the NFS wizard ot the turn wizard?
I fixed the one in the turn wizard but not the NFS... I didn't think there was a problem in the NFS wizard. I will fix it ASAP if you tell me more.
Thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
Vmax
« Reply #2 on: December 10, 2005, 07:28:54 PM »
Sorry Brian I should have explained further. We had talked about doing a rigid type tapping scheme and use a slipjoint tap holder
I can set up the Drill wizards for taping but it will not be rigid  taping... Mach3 can not rigid tap, but you can run a floating tap holder and tap.
What I will do is add in a setting for tap and have a dialog box pop up with a few questions that you will have to answer.
Thank you for the input
Brian
« Last Edit: December 10, 2005, 07:31:11 PM by Vmax »
« Reply #3 on: December 10, 2005, 11:24:26 PM »
I see :) I was thinking bout thread milling :-)
It is on the list and I think it is going to be soon
Brian
www.machsupport.com
