Hello Guest it is June 13, 2026, 02:37:31 AM
Author Topic: Can A Modbus control a.........  (Read 96495 times)
Re: Can A Modbus control a.........
« Reply #50 on: July 30, 2008, 03:10:14 PM »
Just so many ways to do a toolchanger.
 It just goes to show how versatile Mach is :)
Offline TT350
  •  113 113
« Reply #51 on: August 02, 2008, 10:36:49 AM »
Well I think I have a plan.
I will use a Smooth Stepper to get two parallel ports and use one to control the brake out board I have now from
port 1 and add another brake out board to port 2 to handle the TC axis and I/O's to and from the PLC.
What do you guys think?
« Reply #52 on: August 02, 2008, 01:25:53 PM »
Should work fine.
 Added cost of the SS and BOB may be almost as much as getting a module for the PLC to control the axis but the added benefit of the SS is that it will allow much more than the PP will in terms of frequency and smoothness of the pulse.
 You would probably be better handling the I/O from the PLC to the computer  over Modbus rather than through the port.
Offline TT350
  •  113 113
« Reply #53 on: August 03, 2008, 05:33:39 AM »
What is PP?
« Reply #54 on: August 03, 2008, 05:35:35 AM »
Paralllel port :)
Offline TT350
  •  113 113
« Reply #55 on: August 03, 2008, 05:37:26 AM »
Thanks Hood!
« Reply #56 on: January 30, 2011, 04:02:23 AM »
How can I use event driven serial control in Mach3?
