Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 01:44:36 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
VB and the development of wizards
Denford lathe 8 position BCD (3 input slot reader), ATC M6
Pages:
1
Go Down
« previous
next »
Author
Topic: Denford lathe 8 position BCD (3 input slot reader), ATC M6 (Read 2285 times)
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline
Briceville, TN, USA
on:
July 11, 2008, 10:46:47 AM »
Here is an M6 for a 8 position Denford ATC, the kind that has a 3 input slot reader to code the position of the turret. Also, it has an output that turns on an output that runs the ATC forward at 24 volts, once it is at the correct tool position, the signal dies, and reley goes back to a 12 side that runs the turret backward and locks it, the 12 volt is always on unless moving forward for new tool.
This is from a request from a guy on the CNC zone that has this kind of set up.
Resources:
INPUTS1, 2 and 3 (sensors that read the slot pattern in the turret to code tool/slot number.
OUTPUT3 (this turns on the releay to flip over to the 24 volt opposite polarity side, to run the turret forward in a search for the next tool, it deactivates when the "3 digit" binary code from the inputs above match the Tool/slot for the new tool, it then reverses and locks into position
'M6Start.M1s
Sub Main()
NewTool = GetSelectedTool()
OldTool = GetCurrentTool()
MaxToolNum = 8 'Max number of tools for the changer
While NewTool > MaxToolNum
NewTool = Question ("Enter New Tool Number up to " & MaxToolNum)
Wend
If NewTool = OldTool Or NewTool = 0 Then
Exit Sub
End If
If OldTool <> NewTool Then
While Slot <> NewTool
ActivateSignal(OUTPUT3) 'start rotating forward
If IsActive(INPUT3) And Not IsActive(INPUT2) And Not IsActive (INPUT1) Then
Slot = 1
End If
If Not IsActive(INPUT3) And Not IsActive(INPUT2) And Not IsActive (INPUT1) Then
Slot = 2
End If
If Not IsActive(INPUT3) And Not IsActive(INPUT2) And IsActive (INPUT1) Then
Slot = 3
End If
If IsActive(INPUT3) And Not IsActive(INPUT2) And IsActive(INPUT1) Then
Slot = 4
End If
If IsActive(INPUT3) And IsActive(INPUT2) And IsActive(INPUT1) Then
Slot = 5
End If
If Not IsActive(INPUT3) And IsActive(INPUT2) And IsActive(INPUT1) Then
Slot = 6
End If
If Not IsActive(INPUT3) And IsActive(INPUT2) And Not IsActive (INPUT1) Then
Slot = 7
End If
If IsActive(INPUT3) And IsActive(INPUT2) And Not IsActive(INPUT1) Then
Slot = 8
End If
Wend
Sleep(100)
DeActivateSignal(OUTPUT3) 'stop rotating forward, rotate backward now
End If
SetOEMDRO(824,NewTool)
Code "G4 P2" 'A pause time of 2 seconds to give your reverse turret time to seat
While IsMoving
Wend
End Sub
Main
'have fun,
'Scott
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
fisherjim
Active Member
Offline
Re: Denford lathe 8 position BCD (3 input slot reader), ATC M6
Reply #1 on:
August 25, 2008, 12:44:45 PM »
This Macro, slightly changed to suit 4 inputs, also works on my Emco 220 lathe, but is not "safe" as I have Mach3 set up with a switch to manually revolve the turret so as to set up tools. so if the DRO is showing tool 1 and the toolchanger is actually on tool 3 if I enter "tool 1" the changer stays where it is as the control thinks its still on tool 1.
Is there a way to dynamically update the tool number on the DRO as the changer goes round or should I throw away the switch?
Jim.
ahmedrehan
Active Member
Offline
Reply #2 on:
January 27, 2009, 02:53:26 AM »
Hi ,
I have tested the above code it run fine when i run from vb script editor but not run when i run from mach screen as soon as i put m6 t02 it will set the dro to 0 tool no for every value on tool i have also enabled auto tool changer in config.
please help.
Ahmed
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline
Briceville, TN, USA
Reply #3 on:
January 27, 2009, 08:56:03 AM »
on a Lathe the way you have to do your tool change code is slightly different. I.e. for Tool#1 you need to post:
T0101 M6
The first 01 is the tool numer, the second 01 is the offset, the T wiord needs to come before the M6.
scott
ahmedrehan
Active Member
Offline
Reply #4 on:
January 27, 2009, 03:27:42 PM »
Thanks got it working but i have to add 4 bit bcd as tool changer is 10 tools will try.
Ahmed
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
