Hello Guest it is June 10, 2026, 09:29:43 PM
Author Topic: Ignore Tool Change  (Read 37605 times)
Re: Ignore Tool Change
« Reply #10 on: December 09, 2005, 01:09:39 PM »
All the settings are in the XML file and the tool table is in the Mach3\macros\Mach3Mill\tools3 file
when I do this I like to save all the macro's too :)
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #11 on: December 09, 2005, 04:12:51 PM »
Just a followup to the above problem.
I have discovered that if I enable or disable the 'ignore tool change box' using the settings tab, does not save the last known setting on exit. If however I use the boxes in the config/logic setups everything works as expected. Somthing is wrong with that checkbox when using the '(alt6)settings' tab.
Steve
« Reply #12 on: December 09, 2005, 04:15:12 PM »
I didn't even think of the one on the settings page!
Thank you Very good to know!
Brian
www.machsupport.com
