May 28, 2012, 01:43:33 PM
Search:     Advanced search
+  Machsupport Forum
|-+  General CNC Chat
| |-+  Show"N"Tell ( Your Machines)
| | |-+  RICH'S ATLAS CNC CONVERSION
Pages: « 1 2   Go Down
Print
Author Topic: RICH'S ATLAS CNC CONVERSION  (Read 2633 times)
Global Moderator
Offline Offline
View Profile
« Reply #10 on: June 04, 2011, 12:23:21 PM »
The handles can still be used and  manual operation of the quill is possible by a simple disconnect of the Z ball screw nut.
The only problem with the X &Y manual use is that you loose the feel since steppers are attached.
A problem with handles are they can become a safety problem since they turn when using the machine in cnc mode.
 I need to modify their attachment to the screw so they can be free floating if desired.
Pages: « 1 2   Go Up
Print
Jump to:
