December 02, 2008, 09:20:46 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  FAQs
| | |-+  How do I change the z-Axel in Mach3.....
Pages: 1   Go Down
Print
Author Topic: How do I change the z-Axel in Mach3.....  (Read 691 times)
Mikkef
Regular Member
Offline Offline
View Profile
« on: July 01, 2008, 04:20:29 AM »
I have Mach3 ver 3.41 and I need to know wher In the setup I can change the Z - axel.
In the G-code it's G-1.0000 and my Z axel go upp and this is wrong...
I whant to change so the Z-axel go down with G-1.0000...  ???and up with G1.0000
Please let me know how I do this... Thank's
Regards
Mikael
Overloaded
Global Moderator
Online Online
View Profile
« Reply #1 on: July 01, 2008, 07:23:32 AM »
Top tool bar,
Config
Ports and Pins,
Motor Outputs,
Dir. Low Active.   Put a green check mark in there and try it again.
RC
You must learn from the mistakes of others. You cant possibly live long enough to make them all yourself.
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
