December 02, 2008, 10:09:12 PM
Search:     Advanced search
+  Machsupport Forum
|-+  G-Code, CAD, and CAM
| |-+  G-Code, CAD, and CAM discussions
| | |-+  unknown movement in mach 3 using Turbo cad/cam v11
Pages: 1   Go Down
Print
Author Topic: unknown movement in mach 3 using Turbo cad/cam v11  (Read 650 times)
mwdubs
Holding
Offline Offline
View Profile
« on: June 30, 2008, 02:35:19 PM »
when i take my g-code generated from turbo cam to mach3 there is a movement made that dosent exist within the code, its like a phantom move, has anyone ever seen anything like this before.
Overloaded
Global Moderator
Online Online
View Profile
« Reply #1 on: June 30, 2008, 03:07:35 PM »
Could you attach a copy of your code ?
Or at least, the section of the code with an indication of where the PHANTOM move occurs ?
RC
You must learn from the mistakes of others. You cant possibly live long enough to make them all yourself.
mwdubs
Holding
Offline Offline
View Profile
« Reply #2 on: June 30, 2008, 03:43:32 PM »
Sorry, I just saw the error, the G54 had the wrong offsetts called out. Wasnt a phantom move after all, just in a hurry
thanks for the concern
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
