Hello Guest it is June 12, 2026, 12:20:00 PM
Author Topic: How to save as in flash screen?  (Read 34139 times)
« on: June 25, 2008, 03:08:05 PM »
Hi
I want to create a button to save(save as) my GCode.
I create this button in Screen4(.set), with this code:
Set objDialog = CreateObject("SAFRCFileDlg.FileSave")
objDialog.FileName = ""
objDialog.FileType = "Arquivo TAP"
intReturn = objDialog.OpenFileSaveDlg
If intReturn Then
        Set objFSO = CreateObject("Scripting.FileSystemObject")
        If StrComp(Right(objDialog.FileName,4),".tap") Then
             objDialog.FileName = objDialog.FileName & ".tap"
        End If
        Set objFile = objFSO.CreateTextFile(objDialog.FileName)
        objFile.Close
   ArquivoTeach = objDialog.FileName
FileCopy "C:\Mach3\GCode\teach.tap", ArquivoTeach
A=MsgBox ("Arquivo salvo como " &  ArquivoTeach, 0, "SALVO")
End If
However, now I am working in development of flash screen and that code do not work.
If someone know the code to create this button tell me please.
That's it.
Re: How to save as in flash screen?
« Reply #1 on: June 25, 2008, 06:32:03 PM »
Yea here is a way to do what you want:
On the Frame, or Frame number index that you want this button to execute put a Dynamic Text Box,
and Name it: "SaveAsGcode" (box immediatly under the Dynamic text selection dropdown in CS3.
Inside the Text Box put this text:
'**********start of Text****************
If intReturn Then
        End If
        objFile.Close
End If
'*********End of Text************
THEN in your Button that does the above operation put this FS command.
on (release) {
   fscommand("VBMacro", SaveAsGcode.text);
// That will run your Original VB code from within flash
//scott
