December 02, 2008, 03:31:21 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Modbus
| | |-+  modIO @ SS
Pages: 1   Go Down
Print
Author Topic: modIO @ SS  (Read 744 times)
maxamillionaire
Active Member
Offline Offline
View Profile
« on: June 23, 2008, 11:58:32 AM »
hi,
this maybe a simple question but as im new to this stuff id like to ask people that know
i have a smooth stepper thats on its way ( should be here tomorrow )
i was wondering if i can plug a modIO into the smooth stepper on the 2nd parallel port that is available?
is this possible and will it still work the same?
i want to run my machine off a laptop when it is done but it only has usb ports if i can't do this i will have to build a pc into my machine
Peter Homann
ModIO Adviser
Active Member
Offline Offline
View Profile WWW
« Reply #1 on: June 23, 2008, 06:51:51 PM »
hi,
Hi Max,
No the ModIO cannot plug into the Smoothstepper. The ModIO communicates with Mach via a serial port.
If you only have USB ports, then you will need to use a USB to serial converter to connect the ModIO.
Note that not all USB to RS232 converters work with Modbus. The one I recommend is this one as I have tested it and know it works.
http://www.dontronics-shop.com/easysync-premium-gold-usb-rs232-adapter-cable-1-meter-cable.html
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
email: peter at homanndesigns.com
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
