Mach3 CNC Full System Integrator services:
Greetings,
I would like to offer my services to do any Regular or High End Mach3 Control
System(s) for your company. My name is Scott Shafer, ("PoppaBear", from the Mach Support forum). I am a Mach3 Controls integrator, my company, S S SYSTEMS, LLC is listed on the Mach3 Support site by Art Fenerty.
Services offered:
Custom Mach3 Screens, both regular and Flash Screens. This includes live "Movie" style Help topics, at the CNC control.
VB Wizards, Macro's, and Macro-pumps.
Advanced I/O, including Mod-bus/Brains, PLC's and other Mod-bus devices, this includes Serial and TCP, (advanced CNC Controls, multiple analog overrides, custom physical button interfacing).
TCP Mod-bus up to 2048 points of I/O (discrete or 16 bit register).
Serial Mod-bus up to 256 points of I/O (Pendants, Physical CNC control interface).
Advanced AC and DC Servos, Stepper, VFD Drives interfacing with Mach for complete parameter monitoring and control. Any Drive system that takes Step and direction or Analog (requires converter). Sure Servo, Danaher, Kol Morgan, Pac-Sci, others.
External motion Board interfacing of: Smooth Stepper, Galil
Standard Para-ports and full Panels.
Mod-bus control of: Plasma/Laser/Water Jet/welder/torch control (for devices that have CNC control interfacing). This includes interfacing with Other Com models like Can-bus, Profi-bus, and others through intermediary PLC's.
C++ plug-ins available
Complete Machine Design, Build, or Retrofit any type of CNC/Industrial Machine, ATC's, Pallet Changers, DNC, Pick and Place Robotic Loaders/Unloaders/conveyor systems, and Machine Cells.
Typical Machine control, and Machine builds: Routers (standard, Laser, Plasma, water jet), Mills 3-6 axis with ATC's, Pallet changers, Lathes 2-4 Axis with ATC's, Bar Pullers, Drop Spindles, Foam 2-4 axis, Wire EDM 2-4 Axis, 2-5 Axis Jog-learn Spinning Lathes, 5 Axis Trunion Mills, Hydraulic Pipe Benders, CNC Saws 3-5 Axis, Six Axis Dual Spindle, Dual Y, Planer Mills, and other purpose build industrial machines.
On site consulting, (international travel available)
On site Training as well (will travel), for both users and OEM manufactures.
HMI/PLC driven industrial machines as well using ADC PLCs.
Notes:
At the "Mach3 CNC Convention S. E" we had about 80 people show, and ½ where OEMs from all over the Globe.
The 2nd Annual convention will be Feb 09.
S S Systems, LLC
1 (eight six five) 426-9728
PO Box 254
Briceville, TN 37710
Poppabear @ hughes.net (remove spaces around the @)
http://ss-systemsllc.com/default.aspx
